Brake problem
uffda
On a 2016 Range Rover, the front brake on the drivers side locks up when the temp gets above 60 degrees F. The calipers have been replaced, but that did not help. the caliper got really hot along with the rotor. What could this be. Also the "lift" does not work when the brakes act up like this. "Lean tilt" in yellow lights up . What is this all about.
